The License screen shows the details of your trial, and if your license is activated, it will show your license key and duration of license.
Each license is unique to the device profile or computer you're using it with and can only be used once. You can click your email address at the top right of the
screen and choose a different device profile.
If you want to use HideAway on more than one of your computers at the same time, you'll need more than one license key.
When you enter a license key, a master profile is created. If you use this master profile on a 2nd computer, HideAway will pause working on the initial computer, or you have the option of entering a license
key for the 2nd computer and creating a new profile name.
Each device profile is unique in that it has its own rules.
HideAway in Trial Mode
HideAway starts in Trial mode. This gives you 30 minutes of use, followed by 5 minutes when HideAway pauses. After the pause, you must Resume HideAway again to activate the rules.
Purchase a license key
The link to purchase a license key is http://www.firetrust.com/en/products/hideaway-secure-unlimited-vpn/buy
Enter license key
Enter your license key. Each license key is unqiue to each device profile and once used on that device profile, cannot be used on another.
Activate license key
Press the Activate button to activate the license key.
