HideAway requires you to use a login called a Firetrust Login (consisting of an email address and a password). You use this login for each computer you have HideAway running on.
Login for existing users
If you already have a Firetrust Login (If you have used MailWasher Mobile, it's the same login), use this here.
Reset your password
Click to reset your password if you have forgotten it.
New Users - Create Login
New users will need to create a Firetrust Login which consists of an email address and a password.
