The speed screen shows the latency/ping with upload and download speed of each server relative to your computer.
Ping = The amount of time it takes for a packet of information to get from your computer to the server and back again. Locations closer to you will have a lower (better) ping and will perform
better than servers further away.
A measure of latency, or how long it takes for information to go and come back
Connect to the server with the lowest ping to ensure you get the best speeds, depending on your requirements of course.
