When you login to HideAway you'll see this screen to choose a device profile. Each of your computers can have a unique device profile with different rules for each device/computer.
Choose the Master profile if you only have one computer, if you will use HideAway on a 2nd computer then choose to Add another computer.
If you want to use HideAway on more than one of your computers at the same time, you'll need more than one license key.
If you use this master profile on a 2nd computer, HideAway will pause working on the initial computer, or you have the option of creating a different device profile.
Each device profile is unique in that it has its own rules.
EDIT PROFILE NAME: Once logged in you can edit your profile name by clicking on your email address and then the gear icon. You can then edit the name of your profile by clicking the pencil icon.
DELETE PROFILE: Once logged in you can delete your profile by clicking on your email address and then the gear icon. You can then delete your profile by clicking the trash icon.
Master is your main device profile
The Master device profile is your main profile if you are only using HideAway on one computer.
Add a 2nd computer
To add a 2nd computer, enter a name of the computer (eg Laptop) and click Save.
