HideAway will order any preset rules by priority but you may need to move any custom rules yourself.
You need to order your rules by priority because you will want some rules to take priority over others.
For example, if you have a website rule for BBC iPlayer which goes through the United Kingdom, but you have a Google Chrome rule which redirects all your web browser traffic through Germany then you will want the BBC iPlayer
rule to take priority over the Google Chrome rule so BBC iPlayer rule still works.
Websites should take priority over applications, so websites belong at the top. If you have a country redirect rule enabled, that rule should be at the bottom.
Drag and drop rules to re-order priority
Click and hold your left mouse button on the left end of a rule and move your mouse to the new location for this rule. Release the mouse button to drop the rule where you want it.
