To get here: On the MY RULES page, click the ADD NEW RULE button, then click CREATE NEW RULE button, then the ADVANCED button
The Advanced Create Rules screen lets you add individual filters under one rule to give you more flexibility in how you redirect your internet traffic through HideAway.
Enter a rule name
Enter a name for this rule
Enter a description
Enter a description for this rule
Toggle encryption on or off
Decide if encryption will be enabled or disabled for this rule
Choose a location for this rule
Choose the location this rule will have its internet traffic redirected through
This table lists all the filters inside a rule
Each rule consists of one or more filters. This table lists each filter and its properties.
Delete this filter
Click to delete a filter
Add a new filter to this rule
Add extra filters to the rule. Each rule can have one or more filters
Change properties for this filter
Click to change the properties of each filter. You can choose to redirect, exclude or ignore a rule and select a process, website domain, IP address and port to act on.
Go back to the basic custom filter editor
This button takes you back to the basic filter editor.
