To get here: On the MY RULES page, click the ADD NEW RULE button
The Preset rules screen lists preset rules which are already configured to use. Click the ADD button to add any rule to your MY RULES page so it can be used.
Search for preset rules
Start typing to search for preset rules to use
Click to Add a preset rule you want to use
The ADD button adds this rule to the MY RULES page and enables it for use.
You're already using this rule
When the button is IN USE, that means it's already in use on your MY RULES page.
Create a custom rule
Click to create your own custom rule if you can't find a rule here to use.
